It is currently Tue Nov 17, 2026 4:20 pm
 Post subject: Horn Relay
PostPosted: Thu Jan 04, 2007 6:14 pm
Can anyone provide a part number and/or manufacturer for a horn relay for my Valiant? I depress the horn and the relay clicks but the horn don't blow. Checked all the grounds which leaves me thinking that it's the relay.
Russ
1968 Valiant 100 4 door 225/6
PostPosted: Thu Jan 04, 2007 7:15 pm
What about the horn itself? Unplug it from the harnes and run a jumper direct to battery +12v.
PostPosted: Thu Jan 04, 2007 7:26 pm
I totally forgot to check them this way. I'll let you know what happens.
Russ
PostPosted: Fri Jan 05, 2007 2:58 pm
I jumped the horns today and they were non responsive so me thinks that you are right. I am going to take the horns out of my ford and test them. If they work I will be needing replacements. :shock:
Russ
