| Horn Relay https://slantsix.org/forum/viewtopic.php?t=21326 |
| Author: | 68Valiant [ Thu Jan 04, 2007 6:14 pm ] |
| Post subject: | Horn Relay |
Can anyone provide a part number and/or manufacturer for a horn relay for my Valiant? I depress the horn and the relay clicks but the horn don't blow. Checked all the grounds which leaves me thinking that it's the relay. Thanks Russ |
| Author: | Pierre [ Thu Jan 04, 2007 7:15 pm ] |
What about the horn itself? Unplug it from the harnes and run a jumper direct to battery +12v. |
| Author: | 68Valiant [ Thu Jan 04, 2007 7:26 pm ] |
I totally forgot to check them this way. I'll let you know what happens. Russ |
| Author: | 68Valiant [ Fri Jan 05, 2007 2:58 pm ] |
I jumped the horns today and they were non responsive so me thinks that you are right. I am going to take the horns out of my ford and test them. If they work I will be needing replacements. Russ |
