It is currently Sat Nov 21, 2026 11:53 am
 Post subject: Choke modifications....
PostPosted: Sun Feb 11, 2007 2:57 pm
I have read in past posts about using a slant six pushrod, to make a "unified" choke set-up.(For a 2X1 intake.) SSDan, I read in several places were you said it was possible to do a 1920 this way? What would be involved in doing this? (I did use the "Search" feature, but could never find a detailed post about how this was done.)
Thanks,
BBBanjo
225 Cubic Inches of Iron-Head American Muscle
225 bored .040 /.100 off block, Schneider Cam 224@.050~ .480 lift - Stock valves, blended bowls, Offenhauser intake with 500 Edelbrock carb
PostPosted: Sun Feb 11, 2007 3:27 pm
Funny you should ask. I was looking at the 2X1 mainfold sometime back and saved that info. You'll find it here: http://www.slantsix.org/forum/viewtopic.php?p=77236
David Kight
'62 Valiant Signet, White
'98 Dodge Dakota
'06 Jeep Liberty
PostPosted: Sun Feb 11, 2007 3:33 pm
The pushrod trick is contingent on using carburetors without linkage or vent parts in the way of the projected axis of the choke rod and air cleaners that also don't impinge on the pushrod area. I think the better and easier way of doing it is described and pictured here.
