It is currently Thu Nov 19, 2026 9:30 pm
 Post subject: Flywheel
PostPosted: Wed Jan 31, 2007 10:05 am
Need to know if a 130 tooth 10 inch flywheel and pressure plate will fit
in the multi- bolt pattern bell housing. Also will the starter from the 122 tooth flywheel work.
PostPosted: Wed Jan 31, 2007 8:59 pm
A 130 tooth flywheel will not fit in a 122 tooth (SL6) bellhoushing.
