It is currently Tue Nov 24, 2026 1:04 pm
PostPosted: Thu Feb 22, 2007 7:41 pm
My 1 bbl carb is leaking gas at the shaft assy. it runs great and I am not ready to go to a super six set up just yet. I have never rebuit a carb, should I buy one or rebuild mine?
Our greatest fear should not be of failure but succeeding at something that doesn't matter.
PostPosted: Thu Feb 22, 2007 8:01 pm
rebuild yours or get a junk core at ebay or by posting a wanted parts add here, you'll have a blast learning to rebuild your carbs, save big bucks on poorly reman works done by kinda reputable shops, and save big bucks on aspirine later when you discover you've turned in your fine working but leaky throttle shaft carb for a clean looking but completely junked, ill functioning piece of reman crap work.
Holley or carter?
Juan Ignacio Caino
PostPosted: Thu Feb 22, 2007 10:43 pm
I rebuilt my 1 bbl carb in under an hour, it was my first try. It was pretty easy, just make sure you keep track of how the parts came off, and if you have a carter make sure you don't lose those little balls in it.
-Allen
1962 Valiant V-200
170 C.I. Super Six, HEI, Dutra Duals
 Post subject: carb
PostPosted: Fri Feb 23, 2007 7:30 am
If you don't feel like rebuilding it your self you can take it to a carb shop. But it dose get spendy sometimes.
PostPosted: Fri Feb 23, 2007 7:57 am
Remember, rebuilding the carburetor by disassembling, cleaning and installing a carb kit will not fix the leaks-at-the-throttle-shaft problem. To fix that, you would need to have your carburetor's throttle body rebushed, as described here.
Do not buy a "remanufactured" (or "rebuilt") carburetor from the parts store, they are garbage (and most of them will need rebushing at least as badly as yours does!) See here.
PostPosted: Sat Feb 24, 2007 8:25 pm
Thanks to all for the advice.
Users browsing this forum: Amazon [Bot], Bing [Bot], DuckDuckGo [Bot] and 8 guests
