It is currently Tue Nov 24, 2026 11:00 pm
 Post subject: New dizzy
PostPosted: Tue Feb 27, 2007 5:58 pm
It arrived today, so what do I have and what do I need to do with it? The vacuum pot is marked as 8.5R and the blue tag on the side reads:
20 9
3755042
It appears to be shop worn but I don't believe it's ever been in an engine.
David Kight
'62 Valiant Signet, White
'98 Dodge Dakota
'06 Jeep Liberty
PostPosted: Tue Feb 27, 2007 6:22 pm
3755042 is a stock '73-'74 slant-6 passenger car distributor. Should work well as is, and if you want you can tweak the advance curves later.
I recommend the HEI upgrade, install a NAPA Echlin long-tip rotor # MO-3000 with Standard-Bluestreak CH-410X cap and (if you have a '74-down head w/spark plug tubes) put in NGK ZFR5N plugs gapped to 0.045".
PostPosted: Tue Feb 27, 2007 6:27 pm
I was hoping that it was a stock distributor and not a "high performance" unit with whacked out advance curves. Thanks for the quick answer!
David Kight
'98 Dodge Dakota
'06 Jeep Liberty
 Post subject: Neat!
PostPosted: Tue Feb 27, 2007 8:03 pm
Actually the curve on that guy is very lazy (at TDC it lays in something like 18-20 degrees of mechanical advance at highway speeds- and I can't get the 1 barrel car to rev high enough to get the whole 15R=30 degree limit either), and I have had some good success on "Beater Valiant" using this distributor set to 5 BTDC initial (stock it's set at TDC, and kind of "sluggy" with the stock 1 barrel A-904)...
Later you can set the curve on it easily as per previous articles...
Cool!
