It is currently Tue Oct 13, 2026 10:43 pm
 Post subject: PCV Etc.
PostPosted: Sat Mar 03, 2007 7:23 am
Over the past couple of days I've researched and read every scrap of information I could gather on the topic of PCV valves and air breathers. Am I correct in thinking that the breather on the valve cover is where fresh air is drawn into the motor, and the PCV valve is the exit point from the engine? The reason I am confused is the air breather also has a hose plumbed to the air filter thereby drawing air which would further pass through the carb, exhaust, etc. Why the extra hose to the air cleaner?
PostPosted: Sat Mar 03, 2007 8:17 am
Good question. See this post.
I also, again, recommend you buy all three of the books described in this thread.
 Post subject: breather hose
PostPosted: Sat Mar 03, 2007 8:22 am
i always though it was for emmission to filter and burn excess vopor but it doesnt see vac pressure like pvc does
Last edited by terrylittlejohn on Sat Mar 03, 2007 8:25 am, edited 1 time in total.
PostPosted: Sat Mar 03, 2007 8:24 am
For Dan: I've gotten the books. Just trying to clarify what I am reading. Thanks.
PostPosted: Sat Mar 03, 2007 9:36 am
Oh, you've got the books? Terrific. If it's still unclear after hitting the thread I linked to above, then take a read through the emission control section of the Peterson book. It has a very detailed explanation of PCV systems, with pictures and diagrams.
Users browsing this forum: DuckDuckGo [Bot] and 17 guests
