It is currently Wed Nov 25, 2026 12:15 am
 Post subject: Grease tie rod sleeves?
PostPosted: Sat Mar 10, 2007 7:09 pm
I just replaced my steering box and pittman arm. The steering wheel is a little crooked, so I am going to have it aligned on Monday. Since I have a front end kit I got from ESPO a while back, but haven't used yet, I figured I would replace all the tie rods and sleeves before it goes in for alignment.
My question, do you grease the inside of the sleeves? On one hand, it seems like this would good to minimize corrosion over the long run, but maybe it will make the adjustment prone to shake out of adjustment in driving? (Obviously I will grease the zerks on the tie rod ends)
 Post subject: tie rod adj sleaves
PostPosted: Sun Mar 11, 2007 3:03 am
If want to make an alignment friend anti-seize no grease please dirt magnet see you at the shop.
'72 Image Duster /6 with turbo build up
'03 Ram 2500 4x4 w/HEMI 5sp 4:10 posi
My Twister Page
PostPosted: Sun Mar 11, 2007 4:45 pm
Thanks!
