It is currently Tue Oct 13, 2026 12:58 pm
 Post subject: Creeping crud
PostPosted: Thu Mar 15, 2007 9:08 pm
Here is a link to look at the pictures, http://www.putfile.com/icaneat50eggs What caused this carbon build up on the intakes? The exhaust valves look good. Also how can I remove it without dinging up the valve job? It does not look normal to me.
PostPosted: Thu Mar 15, 2007 9:15 pm
"Coked" oil.
Were the valve stem seals hard and / or broken?
I also see this on engines that never get reved-up, no matter how good the valve guides, stems and seals are.
(you will find a spun bearing before you find any of this valve crud on engines I drive! :twisted: :wink: )
PostPosted: Thu Mar 15, 2007 9:22 pm
I was wondering about the valve seals, they were kind of hard. Should they be more like rubber? The engine has low miles on the rebuild. The #1 and 6 cylinder were kind of sooty looking. Yeah, it doesnt get revved much, But if the "Doc" so prescribes it..... Now how do I safely remove it?
PostPosted: Fri Mar 16, 2007 7:37 am
hi, i have always used a bench grinder with a heavy duty "rope style" wire wheel on one side. clean your valves outside and have eye protection and a breather mask so you don't inhale carbon dust. i have never hurt a valve and they look brand new when done. ron
PostPosted: Fri Mar 16, 2007 8:29 am
The deposits are hard and brittle, strike the crud to chip it off and then bead blast or wire brush to get the last bits.
Yes, valve stem seals should be flexable. Note that the umbrella type seals all look the same (black poly material) but the material used is not the same, cheap seals tend to dry-out and get hard quickly.
PostPosted: Sun Mar 18, 2007 8:56 am
Is it possible to use other types of seals? The heads I used to have on my 360 had BB Chevy ones on it. Those were recommended by the machinist at Music City Rod Shop (RIP) :( I wanted something that would hold up for many miles and take the heat of a 6000lb truck 360 living in a little insulated box.
PostPosted: Sun Mar 18, 2007 9:37 am
With deposits that large I would want to go ahead and do a valve job. If you can't or won't do that, at least lap them in with some good valve lapping compound so that you get a good seal.
David Kight
'62 Valiant Signet, White
'98 Dodge Dakota
'06 Jeep Liberty
Users browsing this forum: No registered users and 15 guests
