It is currently Tue Oct 13, 2026 12:03 am
 Post subject: Rotating Exhaust valves
PostPosted: Fri Mar 16, 2007 4:35 am
Are the ex valves in a slant rotating or non-rotating. I was looking at some spring options and this was a question Edelbrock asked.
PostPosted: Fri Mar 16, 2007 5:13 am
The only Slants I know of with rotators was some of the exhaust valves on industrial engines. The automotive Slants did not. :shock:
PostPosted: Fri Mar 16, 2007 5:30 am
Thank you very much for the quick reply. Ya got any input on Edelbrock Preformer valve springs?
PostPosted: Fri Mar 16, 2007 8:31 am
Keep valve spring pressures light unless you are spinning some high RPMs.
Most people use to much spring pressure in a SL6, especially for "street/strip" engines.
PostPosted: Fri Mar 16, 2007 12:53 pm
When you say light can you give me some numbers I changed cams to a P4286678 and the spring is Edelbrock performer pt # 5877. Ishould be able to use my stock retainers with this spring also.
PostPosted: Fri Mar 16, 2007 2:14 pm
On a street SL6 that stays under 5,000 RPM I target 90 lbs on the seat and 200-220 lbs at full lift
Users browsing this forum: Ahrefs [Bot], Bing [Bot], Google [Bot] and 17 guests
