Rotating Exhaust valves
https://slantsix.org/forum/viewtopic.php?t=22284
Author:  flatiron [ Fri Mar 16, 2007 4:35 am ]
Post subject:  Rotating Exhaust valves
Are the ex valves in a slant rotating or non-rotating. I was looking at some spring options and this was a question Edelbrock asked.
Author:  slantzilla [ Fri Mar 16, 2007 5:13 am ]
The only Slants I know of with rotators was some of the exhaust valves on industrial engines. The automotive Slants did not. :shock:
Author:  flatiron [ Fri Mar 16, 2007 5:30 am ]
Thank you very much for the quick reply. Ya got any input on Edelbrock Preformer valve springs?
Author:  Doc [ Fri Mar 16, 2007 8:31 am ]
Keep valve spring pressures light unless you are spinning some high RPMs.
Most people use to much spring pressure in a SL6, especially for "street/strip" engines.
Author:  flatiron [ Fri Mar 16, 2007 12:53 pm ]
When you say light can you give me some numbers I changed cams to a P4286678 and the spring is Edelbrock performer pt # 5877. Ishould be able to use my stock retainers with this spring also.
Author:  Doc [ Fri Mar 16, 2007 2:14 pm ]
On a street SL6 that stays under 5,000 RPM I target 90 lbs on the seat and 200-220 lbs at full lift
