It is currently Thu May 21, 2026 1:56 am
PostPosted: Mon Mar 19, 2007 7:16 pm
Right now I have the super six setup on my 63 Dodge Dart. The head is in the machine shop to get the compression to 9.0. Now I am looking at it being a great time to add a cam. But we are worried about how much we can do, before it gets too hard on the tranny? I still want to get rid of the points. And that might be where I stop.
PostPosted: Mon Mar 19, 2007 7:27 pm
Don't worry about the transmission. A 904 can be built to handle anything a SL6 can dish-out.
PostPosted: Mon Mar 19, 2007 7:30 pm
Add electronic ignition and an Isky 264, comp 264 or Erson 270. Unless you have a 3 spd manual your trans should be fine.
I know you want to stop there but soon its time for a high stall convertor and a 4 barrel and headerz.......
If it helps ,,,,my Valaint is a 65 with 9,25 compression ratio,,,,comp 264 and a super 6 . The weak link is the 7.25 rear.....
PostPosted: Mon Mar 19, 2007 7:49 pm
Thanks. That will be a green light for me I guess.
I don't know why it keeps showing 4 BBL Hyper Pak for me, when I do the posts. I can't see where that got picked up from.
Once again, I appreciate the help.
PostPosted: Mon Mar 19, 2007 7:58 pm
That is just an activity indicator. There are different levels depending on how many times you post. You will see that change as you participate more.
David Kight
'62 Valiant Signet, White
'98 Dodge Dakota
'06 Jeep Liberty
Users browsing this forum: Bing [Bot] and 10 guests
