It is currently Fri May 15, 2026 7:11 pm
 Post subject: 904A with overdrive
PostPosted: Fri Mar 23, 2007 12:18 am
I picked up a mopar action the other day and was reading that there is now a kit to put a electrionic od on a 904a by keisler. My question is, is a kit or a hole new trans. and will it work with the high start? Anyone else read this. mopar action april 2007 it start on page 72. If so, would it be a good investment
225+0.080 at 10:1
268cam
holley 390
clifford headers
8 3/4 355's lsd
kh brakes
electronic ing
 Post subject: Re: 904A with overdrive
PostPosted: Fri Mar 23, 2007 1:00 am
Mm. See here and here.
Don't see mention of any such a kit on Keisler's site (they want you to replace your Torqueflite with a Tremec unit, and don't offer it with slant-6 bellhousing pattern), but Gear Vendors will sell you an electric-overdrive tailhousing replacement for an A904. Got a spare $3K...?
PostPosted: Fri Mar 23, 2007 4:03 am
For the cost of adding another gear that way you can buy a lot of fuel.
PostPosted: Sat Mar 24, 2007 6:08 am
For 3.2K you can get a Richmond 6-spd w/ OD from Summit. From the little research I've done it looks like you're stuck having to have a bellhousing (or adapter) specially made for it though. Now THAT would be a cool way to go if it could be done without alot of heartache (and wallet pain). Myself I just read an article in this month's Car Craft about a new gearset for the 833 that offers an OD 4th gear. Looks like it'd be a great way to go for a slant powered car.
