It is currently Tue Nov 24, 2026 1:32 pm
 Post subject: addco bar - late disks
PostPosted: Fri Mar 23, 2007 2:36 pm
I'm starting to fit the Addco front sway bar to the 64 Val.. The LCA tabs bolt to the lower shock bolt. This got me thinking, unfortunately....
I'd like to make sure that the bar will clear the later A, disk conversion and 14" ralley wheels. anyone know if it does? the sway bar is ~ 2" further outside than the LCA strut. Pict to follow.
thanks....
PostPosted: Fri Mar 23, 2007 2:38 pm
Dont know bout ralley wheels but the rest is a go.......
PostPosted: Sat Mar 24, 2007 5:14 am
I'm running an Addco bar with the Mopar Action disc brake conversion, with the calipers mounted to the rear of the spindles. Haven't had any clearance problems with the sway bar. Although I am running 16" wheels.
"Mad Scientist" Matt Cramer
'66 Dart - turbocharged 225
PostPosted: Mon Mar 26, 2007 8:29 pm
I have a firm feel bar that mounts through the shock bolt on a 64 valiant. I have no clearance issues with KH discs or 14" steelies
PostPosted: Tue Mar 27, 2007 10:26 am
I have Addco bars on my two 65's and I had to bring the ends of the bar in a little bit to clear my front-mount calipers at full lock.
Big pipe and a red wrench did the trick.
O==\=/==O
"A mechanic is Somebody."
- Jim Preston
