It is currently Thu Oct 22, 2026 3:40 am
 Post subject: EFI questions
PostPosted: Mon Jun 04, 2001 8:02 pm
Read Bob DiBiase's wonderful article on fuel injecting the slant with Buick batch fire EFI. Today I picked up the MAF sensor, the O2 sensor, the injector harness and injectors for an '86 3.8. These seemed to be the only parts on this engine that qualified for this application. Question is this, when I pulled the injectors from the manifold the brass end stayed in the manifold on several of them. I pulled these brass end caps from the manifold and saved them, and wonder if they can just be cleaned and pressed back on, or if they are damaged beyond use somehow? Appreciate in advance your help.
spowell@aol.com
 Post subject: Re: EFI questions
PostPosted: Mon Jun 04, 2001 10:10 pm
: Read Bob DiBiase's wonderful article on fuel
: injecting the slant with Buick batch fire
: EFI. Today I picked up the MAF sensor, the
: O2 sensor, the injector harness and
: injectors for an '86 3.8. These seemed to be
: the only parts on this engine that qualified
: for this application. Question is this, when
: I pulled the injectors from the manifold the
: brass end stayed in the manifold on several
: of them. I pulled these brass end caps from
: the manifold and saved them, and wonder if
: they can just be cleaned and pressed back
: on, or if they are damaged beyond use
: somehow? Appreciate in advance your help.
I got the injectors that I used from an '85 3.8L engine. These had plastic tips that I replaced with parts that came with the Tomco injector seal kit (P/N 27007, $12). I would guess that there is also a kit for the injectors used in the '86 3.8L engine. However, the metal tips may be more difficult to replace.
Bob D
BBobbias@aol.com
PostPosted: Tue Jun 05, 2001 11:13 am
I should also point out that you won't be able to use the injector harness that you got from the '86 3.8L. The '86 is a sequential system and as such uses a different harness. As you said you can use the MAF and O2 sensor. You should also be able to use the fuel pump relay and the throttle body along with the IAC motor and TPS.
Bob D
BBobbias@aol.com
Users browsing this forum: Ahrefs [Bot], Amazon [Bot], Bing [Bot] and 26 guests
