It is currently Mon May 11, 2026 10:46 pm
PostPosted: Thu Jun 07, 2001 11:56 am
Just checked with a dealer for replacement torsion bars for my 1980 Dodge Aspen and I was told they have been discontinued. The bars on this car are transverse mounted and positively locate the lower control arm the way strut rods did with the longitudinal bar setup. The torsion bar to lower control arm bushings are available, but not the pivot cushion bushings. It is on national backorder, but may or may not become available. So to eliminate excess lower control arm play, I either need the replacement bars with the bushings or someone who makes the pivot cushion bushings. Can anyone help?
Thank you.
Mitch
mb589@aol.com
PostPosted: Sat Jun 09, 2001 6:25 am
: Just checked with a dealer for replacement
: torsion bars for my 1980 Dodge Aspen and I
: was told they have been discontinued. The
: bars on this car are transverse mounted and
: positively locate the lower control arm the
: way strut rods did with the longitudinal bar
: setup. The torsion bar to lower control arm
: bushings are available, but not the pivot
: cushion bushings. It is on national
: backorder, but may or may not become
: available. So to eliminate excess lower
: control arm play, I either need the
: replacement bars with the bushings or
: someone who makes the pivot cushion
: bushings. Can anyone help?
: Thank you.
: Mitch
Pick up any issue of hot rod or mopar muscle magazine. There should be an ad on the back page of the mag for performance suspension technologies, <A HREF="http://www.p-s-t.com">www.p-s-t.com</A> give them a call they should have everything you need.. happy hunting
slantsix_@excite.com
PostPosted: Sat Jun 09, 2001 4:59 pm
I will call them this Monday. Thank you very much.
Regards
Mitch
: Pick up any issue of hot rod or mopar muscle
: magazine. There should be an ad on the back
: page of the mag for performance suspension
: technologies, <A HREF="http://www.p-s-t.com">www.p-s-t.com</A> give them a
: call they should have everything you need..
: happy hunting
mb589@aol.com
