It is currently Thu Oct 22, 2026 5:25 am
 Post subject: Roller Cams
PostPosted: Thu Jun 07, 2001 9:51 pm
On the subject of roller cams I contacted various camshaft companies 3 years ago and could not find any that could grind the dist. drive gear.The equipment at that time could only grind the gear on the end of the cam. We had a blank made and had Lunati finish it with no gear since we run a belt drive oil pump and Electromotive ignition. We also used lifters out of a hemi.
 Post subject: Re: Roller Cams
PostPosted: Thu Jun 07, 2001 10:15 pm
: On the subject of roller cams I contacted
: various camshaft companies 3 years ago and
: could not find any that could grind the
: dist. drive gear.The equipment at that time
: could only grind the gear on the end of the
: cam. We had a blank made and had Lunati
: finish it with no gear since we run a belt
: drive oil pump and Electromotive ignition.
: We also used lifters out of a hemi.
Hi Mark! You got that bonus money and those movie passes ready for KC? I'm on the way!!!!! HeeHeeHee!
aschumers@aol.com
PostPosted: Thu Jun 07, 2001 10:34 pm
Mark Its nice to hear from you again. I stuck in a roller this year I purchased from Isky. Let me get some time on the cam and I'll let you know what did or didn't happen.
Dave Kelso Wa
damuel@kalama.com
PostPosted: Thu Jun 07, 2001 11:28 pm
Hi Mark- good to here from you
Will
slantsix@netzero.net
PostPosted: Fri Jun 08, 2001 12:32 am
Good to hear from you Mark, thanks for the post. We missed you guys at Columbus but understand why you could not make it.
Guess I will have to scan-in some "Green Team" PICs for everyone. How is Wes doing? Are the cars together and running hard??
Users browsing this forum: Ahrefs [Bot], DuckDuckGo [Bot] and 26 guests
