It is currently Sun May 24, 2026 6:28 am
 Post subject: Ride Height
PostPosted: Sat Apr 14, 2007 10:27 am
hey guys...it seems to me that my front end sits funny "one side higher that the other"...is there any adjusment that will make it even..or is this a big job to fix?
PostPosted: Sat Apr 14, 2007 10:34 am
first I would inspect the rear torsion bar mount then you might be able to adjust the torsion bar by the control arm mount (it is always good to have both torsion bars the same tension)
You need to check your suspension and frame components for excessive wear, damage, and/or rust. If everything else is cool you can adjust the torsion bars to either raise the low side or lower the high side. For best ride and handling you need to get it at least close to factory spec ride height.
David Kight
'62 Valiant Signet, White
'98 Dodge Dakota
'06 Jeep Liberty
PostPosted: Thu Apr 19, 2007 7:02 pm
Got my height problem fixed...i am a happy boy again...now i just need to get my tranny fixed..lol
