It is currently Tue Nov 24, 2026 5:46 am
PostPosted: Sun Apr 15, 2007 10:00 am
I'm ready to install my new stainless steel brake lines.
I know the factory didn't do this, but should I use Teflon tape at each connection?
Waste of time?
Harmful?
--Walt Jackson
PostPosted: Sun Apr 15, 2007 12:11 pm
Brake lines seal on flares, not on the threads. If any fluid gets to the threads in the first place something else is wrong. On new lines you may need to loosen/tighten through several cycles to get everything to seat right. The lines may require a bit of tweaking to get them at the right angles as well.
PostPosted: Sun Apr 15, 2007 7:39 pm
Thanks very much for the advice.
--Walt Jackson
Last edited by Walter Lee Jackson on Mon Apr 16, 2007 4:45 pm, edited 1 time in total.
PostPosted: Mon Apr 16, 2007 1:00 pm
I seem to remember that Fine Lines recommends a little liquid teflon sealant on the back side of the flare and the threads on their stainless steel lines. Unfortunately, I read that after I put a whole FL set on and fought with nagging very little leaks for a long time.
