It is currently Sun Oct 25, 2026 10:11 pm
 Post subject: 225 compression numbers
PostPosted: Thu Apr 19, 2007 7:37 pm
Hi,Does anyone have the factory numbers for a dry and wet compression test? THANKS.
PostPosted: Fri Apr 20, 2007 3:07 am
The factory stresses even number, each cylinder should be with-in 10 psi of the others.
Most factory SL6 engines should fall in the 125 - 155 psi range.
 Post subject: comp. #'s
PostPosted: Fri Apr 20, 2007 2:19 pm
Thanks for the info. Doc!!
