Slant Six Forum https://slantsix.org/forum/ |
225 compression numbers https://slantsix.org/forum/viewtopic.php?t=22804 |
Author: | thomasj6604 [ Thu Apr 19, 2007 7:37 pm ] |
Post subject: | 225 compression numbers |
Hi,Does anyone have the factory numbers for a dry and wet compression test? THANKS. |
Author: | Doctor Dodge [ Fri Apr 20, 2007 3:07 am ] |
Post subject: | |
The factory stresses even number, each cylinder should be with-in 10 psi of the others. Most factory SL6 engines should fall in the 125 - 155 psi range. DD |
Author: | thomasj6604 [ Fri Apr 20, 2007 2:19 pm ] |
Post subject: | comp. #'s |
Thanks for the info. Doc!! |
Page 1 of 1 | All times are UTC-08:00 |
Powered by phpBB® Forum Software © phpBB Limited https://www.phpbb.com/ |
