It is currently Sat Nov 28, 2026 3:01 am
 Post subject: Carb Problem need help
PostPosted: Tue Apr 24, 2007 2:02 pm
1963 Dart 270, slant 6, 3 spd w/holley 1920 carb. Here's the problem: The car starts fine and runs good, until the choke opens all the way, then it starves out for fuel and dies. If I close the choke butterfly a sixteenth of an inch, it runs fine again, let go, it starves out. I'm thinknig that possibly a part came off the accelerator rod from the gas pedal. I need apicture of how the accellerator rod fits through the rubber bushing in the carb. It looks like there should be some kind of keeper at the end of the rod to keep it from moving in the bushing. My service manual doesn't show a good picture of how it's set up.
It happened very suddenly, one day it worked fine, the next day, it didn't, so if anyone can download a picture of the set-up I'd sure appreciate it. I have set the idle screw up as high as it will go, but it doesn't fix the problem.
Thanks in advance!
1963 4dr Dart 270 225 six w/3speed column shift
