It is currently Fri May 15, 2026 4:30 pm
 Post subject: Better clutch for 225
PostPosted: Sat Apr 28, 2007 11:45 am
I need a better clutch for my -65 valiant. i have a stock clutch. i've heard that is possible to put a small block v8 engine clutch in 225 by little modifications? is it possible?
most of all i want a clutch that dosent slip..
i have a manuan 3 speed transmission ( i belive its from mid 70`s chyrsler because it has a syncroniced 1 first gear (was not a option in 65 model) when i try to burn rubber the clutch is slipping (back tyres are size 265/60 R 14). When i´m burning rubber with my winter tyres (size 175/65 R 14 there´s no proplem..
i changed the clutch and pressureplate couple of years ago. the problem was the same and now the clutch / pressure plate are old and worn. i have to change then anyway, so why not tune it up
i would be very happy if someone could help me :)
PostPosted: Sat Apr 28, 2007 7:12 pm
Check here for upgrades
No v-8 Clutches / Pressure plates in a slant - Unless you mean the Small ones used in the 273's - they are the same as a slant.
The link should point you in the correct dorection.
http://www.slantsix.org/forum/viewtopic.php?t=22859
 Post subject: thanks
PostPosted: Sun Apr 29, 2007 1:52 pm
thanks greg.. paljon kiitoksia :)
t. Tuomo
