It is currently Mon Nov 23, 2026 9:02 pm
 Post subject: brown brake fluid
PostPosted: Sun Apr 29, 2007 7:56 pm
what's the best way to clean brown fluid with possibly gunk in the master cylinder, can you flush it using the spout on the brake caliper?
PostPosted: Sun Apr 29, 2007 8:26 pm
Suck the old brake fluid out of the reservoir using a turkey baster of equivalent, then refill it with new fluid. Starting at the front left, work your way around the car bleeding the brakes until you get nothing but fresh, clean fluid from each bleeder valve.
You might consider replacing all of the brake lines though, as they are prone to rust through when the fluid gets as bad as you describe. All those rust particles gotta come from somewhere, and that's usually the inside of the brake line.
Used to own:
'82 Dodge D150
Erson 270 Cam, O/S valves, mild port work, ~9.5:1 compression
Currently fighting with an '85 VW Cabriolet
My other passion
