It is currently Sun Nov 15, 2026 11:34 am
 Post subject: Engine wiring
PostPosted: Sun Apr 29, 2007 9:18 pm
Hello all,
I am putting a '79 225 into my 68 Barracuda.
I need some help with the wiring.
I am switching from the point distributor to the stock electronic ignition. All I have is the ignition control box with the connector (with about 2 feet of the wiring). I believe I will need the 79 ballast resistor, but I do not know what wire goes where.
I am also planning on switching from the old 2 wire alternator to the 3 wire that the '79 came with. I need help with the wiring on this also, along with suggestions on any additional parts that may be needed.
Thanks in advance for the help.
PostPosted: Mon Apr 30, 2007 9:37 am
http://www.slantsix.org/articles/elect_ ... wiring.htm
