It is currently Mon Nov 16, 2026 7:08 am
 Post subject: air cleaner
PostPosted: Mon Apr 30, 2007 5:39 pm
does anyone make an open element aircleaner to fit the holley 1920? about 10inch diameter?
PostPosted: Mon Apr 30, 2007 5:48 pm
Some people aren't crazy about an open-element air cleaner, but they look cool. :)
I have one(brand-new) for sale, but be warned: It's a "home-aid" version! :D
It looks like a hundred bucks on the engine, but it isn't as nice underneath.
PM me with your E-mail, and I'll send you some pics if you want.
BigBlockBanjo
PostPosted: Mon Apr 30, 2007 7:05 pm
Open-element air cleaners look cool (some think) but they don't work as well as the factory units.
PostPosted: Mon Apr 30, 2007 7:08 pm
My point is made.....hehe :D
PostPosted: Mon Apr 30, 2007 8:20 pm
The unsilenced air cleaners used in the '60s are the same as an open element cleaner. The ones from '67-'69 were about 10".
Slant Cecil
PostPosted: Mon Apr 30, 2007 8:26 pm
WHYZAT?
PostPosted: Mon Apr 30, 2007 10:26 pm
Because Dan said so...
PostPosted: Tue May 01, 2007 4:37 am
Oh boy...
82 D150-225/727
02 Dakota-3.9/5 speed
PostPosted: Tue May 01, 2007 6:02 pm
WHYZAT?
He's referring to the fact that an open air element does pull in more hot engine air,... it forms a low pressure area over the carb inlet. (Because the air rushing straight through the element goes right over the top of the carb, causing a part-throttle stumble)
It's also harder to hook up a "positive"(?) PVC system....you have to run a small breather on the valve cover. I'm sure I forgot another reason.
Oh yeah, you lose your carb "hot-air" system.
Pro's and Con's. Just make sure you like it, it's your car. It's not like you can't change it right back if you don't like it.
My .02
BBBanjo
