It is currently Tue Nov 17, 2026 1:04 pm
 Post subject: gaskets
PostPosted: Fri May 04, 2007 1:10 pm
Hello,
I read the article on the website about doing the 350CFM Holley 2bbl conversion, by using the adapter plate on a 2bbl intake manifold. I did this and it works great, however I seem to have vacuum leaks.
In the article it shows the guy using a BBD gasket and a thick Holley 2bbl gasket. My question is can I buy these gaskets individually? If so is there a part number? Or a specific thing to ask for? Or will I have to get rebuild kits for both carbs, and then use the gaskets out of them?
Thanks!
PostPosted: Fri May 04, 2007 10:37 pm
hmm...does someone at least have the part numbers for the BBD and Holley 350CFM rebuild kits?
Thanks!
PostPosted: Fri May 04, 2007 11:47 pm
I cant find the number, I just bought one yesterday at napa. I called holley and gave them the 7448 carb number. It was $25.
Users browsing this forum: Amazon [Bot], Bing [Bot] and 3 guests
