It is currently Sun May 17, 2026 8:39 pm
 Post subject: shocks...edelbrock IAS?
PostPosted: Sat Apr 02, 2011 5:24 pm
Are the Edelbrock IAS shocks still the 'good' ones most people here are buying? I need a set for my '71 Dart w/ 8 3/4 rear. What kind/part numbers do I need? I want to be sure I get the right ones.
Cheapest place online to get them?
PostPosted: Sat Apr 02, 2011 10:05 pm
i got mine from summit a couple years ago. i believe they went for about $79 ea. i'm sure you could find them cheaper somewhere else, but i like summit because they ship fast and are really great about returns.
i'd suggest not dropping money for the shocks unless you've taken a good look at your suspension. i thought the shocks would really help in making a smoother ride, but everything down there works together with eachother. so grab some torsion bars to pair with the shocks and make sure your bushings are all good.
70 Plymouth Valiant 4dr
PostPosted: Sat Apr 02, 2011 11:01 pm
I did everything on my suspension a year ago, but got cheapy shocks due to budget. One failed so i'm getting good shocks now.
PostPosted: Sun Apr 03, 2011 4:47 pm
I like the IAS shocks quite a bit in my '73 Dart with stock suspension in good condition. Had one boot failure, and there is a possibility (slight and uninvestigated) that one of them is creating a particular noise in my car.
PostPosted: Mon Apr 04, 2011 6:19 am
I am a fan of these for a street car. Better handling AND better ride than cheapy shocks.
I did have one come shipped with a faulty gas cylinder (no pressure), but Summit replaced and didn't even want the bad one back.
I have them on my '64 and '68 Darts all around.
Summit sells two diff part #'s for A-body Mopars, but they are only different colors, even though their names might be slightly different... :roll: :?
PostPosted: Mon Apr 04, 2011 5:02 pm
I can't find any coupon codes for summit and i'm about to spend just over $300. Does anyone have a coupon code for them?
