It is currently Fri Nov 20, 2026 10:37 pm
PostPosted: Sun May 13, 2007 9:49 am
Can you run an auto with a HyperPak? The reason I ask is that the manifold extends out from under the carb mount, and I'm wondering what sort of trickery would be required to hook up the kick-down.
Thanks in advance,
Eyman
PostPosted: Sun May 13, 2007 10:33 am
Lokar, my friend. Lokar. Its a flexible cable.
PostPosted: Sun May 13, 2007 4:45 pm
Cool, thanks for that.
PostPosted: Mon May 14, 2007 8:52 am
I run H-Pak intakes with automatics, you need to make some throttle pressure linkage but it is not that hard.
http://www.slantsix.org/articles/hyper- ... inkage.htm
