It is currently Fri Nov 20, 2026 11:21 pm
 Post subject: Update
PostPosted: Mon May 14, 2007 7:15 pm
Here is one that I didnt see coming.
I had the cat changed and almost everything is cleared up.
I am guessing that I had just the right exhaust leak that allowed for me to run and only when under load would the valves get pushed back open causing all my noise (what I thought was piston knock).
I have never seen anything like this. I have seen many different cat problems and can usually say that is the "Cat" but this takes the cake. Even my shifting is smoother. I still hear a little knocking but nothing like before and I can go up a hill with out a problem.
I am still thinking about the rebuild but that can possabily wait unitl I can do it myself.
Here is another question, can the oil pan be removed without lifting the engine? 81 Ram 150. I would like to take a look and see what it looks like in there and replace my pan gasket with something that does not let those little black spots by.
Thanks,
Superman
1981 D150
"The Khaki Machine"
Users browsing this forum: DuckDuckGo [Bot], Google [Bot] and 3 guests
