It is currently Sat Nov 21, 2026 1:27 pm
 Post subject: different flywheels?
PostPosted: Fri May 18, 2007 9:22 am
I was just dodging raindrops in the driveway, attempting to install the flywheel from my early slant six ('60's) onto a later slant six (1975). It appears there is a ridge on the end of the crankshaft preventing this. Now what? adapter flange, mill out flywheel?
/6 '67 Barracuda convertible, electronic ignition, 4-OD, street cam, SBP KH discs, 3.55 SG 7.25" 1" t-bars. Bilstein.
340 '67 fastback, Doug Nash 5-speed.
1988 Toyota pickup work truck
PostPosted: Fri May 18, 2007 9:47 am
The bolt pattern is different as well. You need the right flywheel...or motor.
 Post subject: shoulda known
PostPosted: Fri May 18, 2007 9:50 am
figures... :|
