It is currently Tue Nov 24, 2026 8:14 am
 Post subject: Aspen UCAs
PostPosted: Sat May 26, 2007 9:38 am
I've read lots of stuff on the Disc brake conversions and the use of A-Body vs F-Body components.
My question is this. I have read you can use the F-Body UCAs (and other parts), but if you do you have to cut the adjust bar out and use an A-body bar correct? (This is going on a 66 Dart)
PostPosted: Sun May 27, 2007 7:25 am
Get an F body UCA (or 3) to play with. All will be revealed for very few dollars. Make sure you use a new set of A body adjusters.
Be a pioneer! ....and if it doesn t work..come back and tell us why.
PostPosted: Sun May 27, 2007 8:58 am
HAHAHA. Probably how it should work but I'm a Wimp when it comes to build something that might have to be torn apart because it failed. LOL
I thought I read it somewhere on here, but maybe not.
