It is currently Mon Nov 23, 2026 6:22 am
 Post subject: Stock fuel PSI?
PostPosted: Mon May 28, 2007 12:46 pm
What is the stock fuel pressure run at? My gauge is reading/ bouncing around 3.75-4.25 psi.
PostPosted: Mon May 28, 2007 1:07 pm
My FSM indicates normal pressure to be 3.5 - 5 psi. Sounds like yours is right where it needs to be. If your guage is teed directly into the output of the stock pump it will bounce because the output of the pump is not steady; it pulses as the arm is pushed up and down by the cam.
David Kight
'62 Valiant Signet, White
'98 Dodge Dakota
'06 Jeep Liberty
PostPosted: Mon May 28, 2007 1:38 pm
I thought it should be more like 6 psi but, if thats what the FSM says, then that good enough for me.
Thank you.
