It is currently Thu May 14, 2026 7:27 am
 Post subject: really need some help
PostPosted: Thu Jul 12, 2001 7:22 pm
1. should the heat riser move back and forth when i give it throttle or should it open up and just stay there when the eng gets hot? mine goes back and forth. also my spring steel "stop" broke in front of the spring. 2. looking aft, which way is the heat riser open when it turns left or right? 3. since my stop broke, the valve gets stuck to the right when looking aft. 4. nobody has a spring kit in the resto mags for a slant 6. can i get 1? 5. can i wire the heat riser open if i can't get the spring kit? 6. thanks doug, i'm drainin the radiator right after this to see if it's clear of crap.
pljaime@gta.net
PostPosted: Fri Jul 13, 2001 10:09 am
: 1. should the heat riser move back and forth
: when i give it throttle or should it open up
: and just stay there when the eng gets hot?
: mine goes back and forth. also my spring
: steel "stop" broke in front of the
: spring.
The valve moves on throttle up and down.
: heat riser open when it turns left or right?
facing the firewall, it rotates counterclcockwise when the carb is opened
: 3. since my stop broke, the valve gets stuck
: to the right when looking aft.
I don't understand. IS that stuck open or stuck closed?
4. nobody has
: a spring kit in the resto mags for a slant
: 6. can i get 1?
Off another car.
: open if i can't get the spring kit?
Yes. I have found htat the later manifolds have better flaps and you might be better off swithcing manifolds. However, i have had those flaps fall completely to peices externally and not noticed any exessive heat or loss of performance.. Even when it is in hte fully closed position it doesnt seal and it bypases like crazy. It is more of a director flap than a valve. It just speads up hte preheat of the carb.
6.
: thanks doug, i'm drainin the radiator right
: after this to see if it's clear of crap.
richard-c@e-d-a.com
