It is currently Fri Jan 30, 2026 10:42 am
PostPosted: Fri Jun 29, 2001 11:17 am
I want to swap in a B.L. rearend and front disks. How can tell the difference between a B.L. A Body 7 1/4 and a B.L. 8 1/4? I found a 73 Dart in the junkyard that has a B.L. rearend and front disk assemblies.
Thanks,
Gary
: Do you want to swap a "big lug"
: (B.L.) 8 3/4 *into* your 66 wagon? If so, do
: not waste your time looking in the junkyards
: for one, the factory never made a "5 on
: 4 1/2" A-Body 8 3/4 rear end.
: You can find the B.L. A-Body 7 1/4 and a B.L. 8
: 1/4 or get the 66-72 A-Body 8 3/4 (small lug
: pattern) and swap-in the special B.L. axles.
: DD
theluketribe@hotmail.com
PostPosted: Fri Jun 29, 2001 7:38 pm
Gary, check the answer to your question under my post above. Some folks are confused and think we are the same person.
