| DOC - 8 3/4 rear swap (in or out?) https://slantsix.org/forum/viewtopic.php?t=2343 |
| Author: | Gary [ Fri Jun 29, 2001 11:17 am ] |
| Post subject: | DOC - 8 3/4 rear swap (in or out?) |
I want to swap in a B.L. rearend and front disks. How can tell the difference between a B.L. A Body 7 1/4 and a B.L. 8 1/4? I found a 73 Dart in the junkyard that has a B.L. rearend and front disk assemblies. Thanks, Gary Quote:
: : Do you want to swap a "big lug" : (B.L.) 8 3/4 *into* your 66 wagon? If so, do : not waste your time looking in the junkyards : for one, the factory never made a "5 on : 4 1/2" A-Body 8 3/4 rear end. : : You can find the B.L. A-Body 7 1/4 and a B.L. 8 : 1/4 or get the 66-72 A-Body 8 3/4 (small lug : pattern) and swap-in the special B.L. axles. : DD theluketribe@hotmail.com |
| Author: | Gary [ Fri Jun 29, 2001 7:38 pm ] |
| Post subject: | Re: DOC - 8 3/4 rear swap (in or out?) |
Gary, check the answer to your question under my post above. Some folks are confused and think we are the same person. |
