It is currently Fri May 15, 2026 12:39 pm
Forum locked  This topic is locked, you cannot edit posts or make further replies.  [ 4 posts ]
 Post subject: Doug - oil pan question
PostPosted: Sat Jun 30, 2001 10:08 am
Doug - I read your article in SSRN #21 about the oil pans. You said the "369" pan came on '77-'84 engines (I think, don't have it here at the library with me), but my '73 225 had it stock. A lot of different styles used over the years I guess.
What pan would you suggest for drag racing? A large sump pan for more (?) oil capacity, or a small sump pan like the 369 so the oil stays close to the pickup tube?
 Post subject: Re: Oil pan question
PostPosted: Wed Jul 04, 2001 11:49 pm
: Doug - I read your article in SSRN #21 about
: the oil pans. You said the "369"
: pan came on '77-'84 engines (I think, don't
: have it here at the library with me), but my
: '73 225 had it stock. A lot of different
: styles used over the years I guess.
: What pan would you suggest for drag racing? A
: large sump pan for more (?) oil capacity, or
: a small sump pan like the 369 so the oil
: stays close to the pickup tube?
Thanks for the input on the "369" pan. I think you are correct that these pans were used in earler years. I'm still collecting info. on all the pans and what they came in so everybody please give feedback.
As for small verse large pan sump, I tend to go with the larger sumps to reduce "windage". I weld-in "dams & doors" to keep the oil at the pick-up.
PostPosted: Thu Jul 05, 2001 10:54 am
: Thanks for the input on the "369"
: pan. I think you are correct that these pans
: were used in earler years. I'm still
: collecting info. on all the pans and what
: they came in so everybody please give
: feedback.
here is what I've collected from old parts books
and interchange books:
G,RG Oil Pans:
2268449 1961-1964 225 A-body, 1964 170 A-body
2268446 1962-63 170 A-body
2406688/2406689 1963-66 225 A-body, 1964-66 170 A-body
(uses pickup/strainer #2206317)
2532284 1966-69 225 B-body, 225 A-100 truck/van,
(uses pickup/strainer #2658696)
2463594 1966-69 225 C-body
(uses pickup/strainer #2463606)
2780904 1969-70 170,198,225 A-body
(uses pickup/strainer #2780999)
3462086 1971 198,225 A,B,E-body
4006368 1973-6 225 A-body, 1976 225 F-body
(sometimes stamped "369")
Doug Ahern
Athens, GA
doug@autohobbydigest.com
 Post subject: Re: Oil pan part numbers
PostPosted: Thu Jul 05, 2001 2:16 pm
Thanks Doug,
Any additional notes or info. on what the differences where on some of these? Looks like I have more "research" to do!
As we all know, finding-out what is out there is an important step, knowing what pans & pick-ups swap into what for the "best" (working) solution is the next piece of time-saving info. I'll keep working on that part so everyone keep "feeding" me info. as you come accross it.
: here is what I've collected from old parts
: books
: and interchange books: G,RG Oil Pans: 2268449
: 1961-1964 225 A-body, 1964 170 A-body
: 2268446 1962-63 170 A-body
: 2406688/2406689 1963-66 225 A-body, 1964-66 170
: A-body
: (uses pickup/strainer #2206317)
: 2532284 1966-69 225 B-body, 225 A-100
: truck/van,
: (uses pickup/strainer #2658696)
: 2463594 1966-69 225 C-body
: (uses pickup/strainer #2463606)
: 2780904 1969-70 170,198,225 A-body
: (uses pickup/strainer #2780999)
: 3462086 1971 198,225 A,B,E-body
: 4006368 1973-6 225 A-body, 1976 225 F-body
: (sometimes stamped "369")
: Doug Ahern
: Athens, GA
