It is currently Tue Nov 24, 2026 6:45 pm
 Post subject: Rusty gas tank
PostPosted: Fri Jun 15, 2007 6:45 am
I read somewhere that someone had the inside of their gas tank cleaned and I just wanted to know where you would have that done at?
Go for it, You live this life only once.
PostPosted: Fri Jun 15, 2007 7:02 am
Look in your local phone book for some radiator repair shops, they usually do that type of work. While you are at it spend a few extra bucks and have them install a tank drain.
PostPosted: Fri Jun 15, 2007 7:16 am
Car Model: 1974 W100; 72 Dart
been down this road before on a-bodies and old trucks. get a new tank. it won't be significantly more than to pay for a tank than the labor at the radiator shop AND you may end up replacing it any way. (at least that is what happened to me)
last tank i had done = $80
tank re-rusted (my fault for being slow)
bought new tank = $120 + shipping
no problems since, but i do say get new gaskets for the filler neck and the sender.
sb
PostPosted: Sat Jun 16, 2007 6:34 am
I do have a semi new tank in my 74 dart it is about 3 years old or so and when I first got it I coated it with por-15 so it shouldn't rust out from the outside
PostPosted: Sat Jun 16, 2007 9:51 am
Where did you get a gas tank for $120, most ive seen are over $200?
Also the little electrical connector part on the outside of the tank broke off, can this be fixed or is it just new tank time?
PostPosted: Sat Jun 16, 2007 5:03 pm
got mine on e-bag.
as far as the electrical tab, is it the one that goes to the sending unit?
sb
PostPosted: Sat Jun 16, 2007 5:35 pm
Yep.
PostPosted: Sun Jun 17, 2007 7:10 am
You can clean it yourself with electrolysis. I did this on an old tractor with such good results that my uncle decided to try it on his corvette. My uncle was going to pay $300.00 for an aftermarket tank but ended up cleaning and sealing the tank for a little over $50.00. www.fboeger.com is where I got my info for cleaning with electrolysis and ebay is where I got the tank sealer. I think I spent about $25.00 doing the tractor. I love ebay.
PostPosted: Sun Jun 17, 2007 7:22 am
That link isn't working for me.
David Kight
'62 Valiant Signet, White
'98 Dodge Dakota
'06 Jeep Liberty
PostPosted: Sun Jun 17, 2007 8:25 pm
Sorry about that. I didnt spell it right. www.fboerger.com but its down for a re-do anyway. I hope he gets it back up. It had a lot of good info on it.
PostPosted: Sun Jun 17, 2007 8:28 pm
don't know how badly busted up your sender is, but they are available new. they come up on ebay all the time and i'm sure there are other sources for them.
i suppose if you put your tank right back into service after having it cleaned by a GOOD radiator shop, it would work out. i'd still see about getting the new filler neck gasket, though. if you are getting a new sending unit, it will come with that gasket.
sb
