It is currently Wed Nov 25, 2026 7:11 am
PostPosted: Mon Jun 25, 2007 11:47 am
Car Model: 63 Dart 81 D150
I have been searching and striking out looking for stock 73-76 disk uca's. With prices of over $100 on ebag for a rebuildable pair, the money is close enough for me to look at new tubular uca's.
My main worry is that this for a daily driver. I like the extra adjustability, but I am worried they might not live long on the street.
I was looking at:
magnumforce (a bit pricey) but maybe worth it?
and
capautoproducts (more in my $ range)
or should I spend the $ on stock arms and the parts to build them?
the car is the otherwise stock 63 dart in the pic below
thanks for your help
TopHat
PostPosted: Mon Jun 25, 2007 11:58 am
Bill Reilly has a damn nice set for the street. www.bigblockdart.com
PostPosted: Mon Jun 25, 2007 2:08 pm
The stock ones work very well, but $100 seems a bit much. Reilly's are the tubular ones to get, as Dennis says.
PostPosted: Mon Jun 25, 2007 7:25 pm
Car Model: 1963 Plymouth Valiant
The tubulars have a bit more favorable geometry than the stock items. And I agree, it's getting harder to find the stock UCA's for a good price.
If you can get a hold of a set of the stock UCA's, get the Moog "Problem Solver" offset bushings for it. You can install them such that you can dial more static caster/camber into the car, which is a plus.
I've never ponied up for tubular arms, but I have done the offset bushings on a couple cars.
PostPosted: Mon Jun 25, 2007 7:42 pm
I bought a set of Magnum Force tubular arms several years ago when they first came out for a b-body,used them on two different cars for several years and assume they are still on the second car I installed them on,they held up great on hard driven daily drivers and allowed for 2 1/2 degrees caster which really helped the handling on twisty roads.
HyperValiant
