| tubular UCA's for the street are they worth it? https://slantsix.org/forum/viewtopic.php?t=23752 |
| Author: | tophat [ Mon Jun 25, 2007 11:47 am ] |
| Post subject: | tubular UCA's for the street are they worth it? |
I have been searching and striking out looking for stock 73-76 disk uca's. With prices of over $100 on ebag for a rebuildable pair, the money is close enough for me to look at new tubular uca's. My main worry is that this for a daily driver. I like the extra adjustability, but I am worried they might not live long on the street. I was looking at: magnumforce (a bit pricey) but maybe worth it? and capautoproducts (more in my $ range) or should I spend the $ on stock arms and the parts to build them? the car is the otherwise stock 63 dart in the pic below thanks for your help TopHat |
| Author: | slantzilla [ Mon Jun 25, 2007 11:58 am ] |
Bill Reilly has a damn nice set for the street. www.bigblockdart.com |
| Author: | Dart270 [ Mon Jun 25, 2007 2:08 pm ] |
The stock ones work very well, but $100 seems a bit much. Reilly's are the tubular ones to get, as Dennis says. Lou |
| Author: | 72polara [ Mon Jun 25, 2007 7:25 pm ] |
The tubulars have a bit more favorable geometry than the stock items. And I agree, it's getting harder to find the stock UCA's for a good price. If you can get a hold of a set of the stock UCA's, get the Moog "Problem Solver" offset bushings for it. You can install them such that you can dial more static caster/camber into the car, which is a plus. I've never ponied up for tubular arms, but I have done the offset bushings on a couple cars. |
| Author: | HyperValiant [ Mon Jun 25, 2007 7:42 pm ] |
I bought a set of Magnum Force tubular arms several years ago when they first came out for a b-body,used them on two different cars for several years and assume they are still on the second car I installed them on,they held up great on hard driven daily drivers and allowed for 2 1/2 degrees caster which really helped the handling on twisty roads. HyperValiant |
