It is currently Thu May 14, 2026 5:11 pm
PostPosted: Mon Jul 09, 2001 10:12 pm
Can 3.23 gears from an A-body 7 & 1/4 rear diff be installed into an F-body 7 & 1/4 rear diff? I would think that they probably would, but I don't know for sure, and I hate to assume.
If someone would let me know, I would appreciate it.
Thanks in advance!
Wes '78 Volare
wes.moeller@compaq.com
PostPosted: Tue Jul 10, 2001 2:48 pm
: Can 3.23 gears from an A-body 7 & 1/4 rear
: diff be installed into an F-body 7 & 1/4
: rear diff? I would think that they probably
: would, but I don't know for sure, and I hate
: to assume.
: If someone would let me know, I would
: appreciate it.
The year(s) are important here. All "early" 7 1/4s used pinion "shims" where "later" ones used a crush sleeve and carrier bearing "adjuster rings". (started in 1970??) For an easy gear swap, you want to use the gears designed for the housing set-up you have.
