| A-body 7 & 1/4 gears in F-body Rear? https://slantsix.org/forum/viewtopic.php?t=2380 |
| Author: | Wesley A. Moeller [ Mon Jul 09, 2001 10:12 pm ] |
| Post subject: | A-body 7 & 1/4 gears in F-body Rear? |
Can 3.23 gears from an A-body 7 & 1/4 rear diff be installed into an F-body 7 & 1/4 rear diff? I would think that they probably would, but I don't know for sure, and I hate to assume. If someone would let me know, I would appreciate it. Thanks in advance! Wes '78 Volare wes.moeller@compaq.com |
| Author: | Doctor Dodge (Doug Dutra) [ Tue Jul 10, 2001 2:48 pm ] |
| Post subject: | Re: A-body 7 & 1/4 gears in F-body Rear? |
: Can 3.23 gears from an A-body 7 & 1/4 rear : diff be installed into an F-body 7 & 1/4 : rear diff? I would think that they probably : would, but I don't know for sure, and I hate : to assume. : : If someone would let me know, I would : appreciate it. The year(s) are important here. All "early" 7 1/4s used pinion "shims" where "later" ones used a crush sleeve and carrier bearing "adjuster rings". (started in 1970??) For an easy gear swap, you want to use the gears designed for the housing set-up you have. DD |
