It is currently Mon Jun 15, 2026 12:46 am
 Post subject: steering swap
PostPosted: Sat Jun 30, 2007 3:17 pm
I have a 64 valiant that I would like to convert from manual to power steering. I know I'll need the brackets and pump from a slant motor but can I get the sector from any A-body? Do I have to change the steering column? Thanks
PostPosted: Sat Jun 30, 2007 4:26 pm
Steering gearbox interchange is '62-'72 A- and B-body. used ones that aren't worn out are hard to find these days; very well refurbished ones can be had from e.g. Firm Feel or Steer & Gear. Yes, you'll need to change at least the steering shaft, or the whole steering column assembly (your preference, no advantage either way), because the P/S shaft is several inches shorter than the nonpower shaft.
You, uh, sure you want to make this swap? Properly set up A-bodies are a delight to drive with manual steering. Power steering adds weight, leaks, belt hassles, and unless you buy an expensive specially-built steering gearbox, takes away all the road feel.
PostPosted: Sat Jun 30, 2007 5:05 pm
what do you mean "properly set-up" ? I don't disagree that it steers easy now, but my wife has a hard time turning the wheel when stopped. How hard is it to take out the steering shaft?
PostPosted: Sat Jun 30, 2007 6:00 pm
Thoughtfully-picked steering box ratio, in good condition, properly lubed, both adjustments set correctly. My preference is the 20:1 manual steering box, which cuts steering wheel turns lock-to-lock from 5¾ to 4&#189 without materially increasing the steering wheel effort. The main nuisance with most nonpower steering cars is that it takes so many turns of the wheel to maneuver the car at low speeds (e.g. parking). The 20:1 box solves that.
We all do! When driving a car without power steering, you simply don't try to turn the wheel with the car stopped -- only when it's rolling. This isn't as awkward as it sounds; it takes only extremely low rolling speed before the steering wheel can be turned with ease. This is simply a matter of un-learning a bad habit that is easily picked up when driving power-steering cars (turning the wheel when stopped is very hard on the tires) . You may save yourself a great deal of time, effort and money if you try education and practise before going on to parts swapping.
Remove steering wheel from steering column; remove and set aside horn contact assembly
Remove clamp bolt or drive out roll pin holding steering shaft coupler to input shaft of steering gearbox, pry coupler rearward off input shaft
Remove steering column from car
Release snap ring at the top of steering column, shaft will slide downward out of column
Install shorter power-steer shaft from bottom of column, install snap ring
Install steering column in car
Install horn contact ring and steering wheel
PostPosted: Sat Jun 30, 2007 8:43 pm
If you are wanting all the parts, I will be swaping over to manual, and will have all the power stuff left over. Maybe you might want to do a swap? shoot me an email.
Andrew/Kidd
Wife's: 64 Valiant
My: 70 Road Runner, 67 Barracuda, AND the 62 Valiant drag car!!
PostPosted: Sat Jun 30, 2007 9:42 pm
tell me more about this 20:1 box? what it came on? how do I know one from the other?
PostPosted: Sun Jul 01, 2007 12:28 am
It is possible to cut the manual steering shaft shorter and drill a hole in the end for the pin, to work in a power steering conversion, without having to find a power steering shaft, if you know exactly how much to shorten it. Anybody have dimensions for this? But then, you can't go back to manual steering without getting a new manual steering shaft.
1964 Dart 225 1966 Valiant 225
1966 Dart 273 1966 Barracuda 273
1969 Dart 225
'64-170 engine '66-170 engine
(two) 198 crank/rod sets in custom-fitted wooden boxes
wooden motor scooter with hybrid-electric drive
PostPosted: Sun Jul 01, 2007 6:15 am
Actually, Flaming River sells an extension shaft to convert from power to manual steering.
David Kight
'62 Valiant Signet, White
'98 Dodge Dakota
'06 Jeep Liberty
PostPosted: Sun Jul 01, 2007 6:44 am
The 20:1 box won't be found in wrecking yards. You can get a completely rebuilt one from Firm Feel (see here) .
PostPosted: Sun Jul 01, 2007 10:02 am
Dan, every time you bring this up I wish you'd mention the fact that you're a very "healthy" gentleman. I know there are lots of other guys who also prefer the road feel of manual steering and don't consider the effort that great, but it's borderline insulting to those of us who HAVE driven manual steering a-bodies and wouldn't even consider driving one every day. And let me assure you that my wife (and countless other women who have driven modern cars) would NEVER choose to drive a manual steering (or brake) car if there was another option, much less consider one a "delight to drive".
I admit that the Mopar power steering is overboosted. I'll take overboosted to non-boosted any day. I feel that just because I choose to drive an old car doesn't mean it should be "work". This goes for manual brakes, too. One of the examples I cite is my brother's '67 disk brake/manual steering Barracuda. It's got a FABULOUS built-up 360 with TONS of power, but (economy aside) I'd take my rusty PS/PB Swinger over his to drive to work everyday without a second thought, because doing anything besides accelerating in his car is WORK.
Must you always try and talk everyone out of power steering? Some of us "puny humans" wouldn't have it any other way.
vm
PostPosted: Sun Jul 01, 2007 11:26 am
Naw, I'm not. Believe me, I'm puny. I have no discernible arm or shoulder muscles and I'm physically lazy.
I would respectfully submit if you find it so difficult that you wouldn't even consider driving one, and the car hasn't got a monster heavy engine or extra-huge wide tires, there is probably something the matter with the car. Too much positive caster, friction in the steering system somewhere, rough bearings in the box...or, as I mentioned before, improper driving technique.
Just offering my opinion, $0.00 worth, same as you're doing. Anyone's free to do with it what he will (or won't). I told the OP to try reworking how he and his wife try to drive the car. They may go "Oh!" and find the problem obviated, or they may not.
PostPosted: Sun Jul 01, 2007 2:40 pm
So I have gathered from this post, that I can use the shaft from within the particularly unattractive manual steering column that I took from a donor car, and insert it into my power steering column as a means of converting to manual steering?(along with the gearbox, of course)
PostPosted: Sun Jul 01, 2007 3:16 pm
Yep, as long as the two columns are of compatible year. What year is your car, and what year is the ugly donor-car column?
PostPosted: Sun Jul 01, 2007 5:34 pm
'73 and '74 respectavly(sp?)
So I DO NOT need to change out any of the other pieces like pitman or idler arms?
PostPosted: Sun Jul 01, 2007 5:50 pm
'73 and '74, yep, no problem there. No pitman arm or other swap needed.
