It is currently Wed Nov 25, 2026 11:22 am
PostPosted: Wed Jul 04, 2007 5:15 pm
Car Model: 1973 Plymouth Scamp
I am in the midst of a rebuild of a ’73 ply scamp 225. Currently this car has manual brakes and is drums all around. Since I have to replace the Master Cylinder I was wondering if it would be advisable to upgrade to power brakes. My questions are:
Will converting to power brakes make a great deal of difference?
Is converting to power as simple as adding a power booster in between the firewall and the MC, and then connecting to the vacuum supply?
Will my factory manual brakes car have the right mounting for the power booster?
With a new MC should I get a power booster from a junkyard?
Am I missing anything with this?
Bruce
Bruce
'73 Ply Scamp 225 1bbl
PostPosted: Wed Jul 04, 2007 5:24 pm
Advisable...? Well, it's certainly possible. There are benefits and drawbacks; only you can decide which outweigh the others.
It'll make the pedal easier to press...is that the goal? It will not shorten the car's stopping distances, unless whoever principally drives the car is extremely weak in the legs or knees and has trouble pressing the brake pedal.
Not quite. You need the booster, the booster brackets, the booster trigger lever, the correct master cylinder for use with a power booster, and you'll need to rebend or remake the master-to-splitter-valve hard lines.
Well, all cars run on used parts! :-) This swap is a lot easier if you get all the parts from one donor car rather than trying to piece it all together from multiple donors. The booster brackets from a '71-up A-body should bolt right onto your '73's firewall.
 Post subject: Thanks FFor the Info
PostPosted: Thu Jul 05, 2007 4:59 pm
Thanks Dan, I think given your comments I will wait on this upgrade. I have enough to do when the "Carcass" gets back from the body shop hopefully later this month. This has been an 11+ month project and I think I'll keep the changes to a minimum.
Bruce
Bruce
