It is currently Mon Nov 30, 2026 7:00 am
PostPosted: Fri Jul 06, 2007 1:20 pm
Will the torque convertor from a 64 v-8 904 swap into a 64 slant six 904? They are both pushbutton transmissions. Thanks for any info!
. . . there was good sport at his making.
PostPosted: Fri Jul 06, 2007 1:32 pm
Yes, the converters are the same and will swap over but the books show the V8 unit as having more stall speed.
I have swapped the factory V8 converters into SL6 applications, hoping I could get more stall speed, never noticed any increase. I think the higher stall rating was based on the converter being used behind a more powerful engine.
PostPosted: Sat Jul 07, 2007 1:48 pm
That's music to my ears (so to speak.) Thanks!
PostPosted: Sat Jul 07, 2007 2:18 pm
Doc-
Confirmed. Same P/N for torque converter used in A904 transmissions behind 170, 225, and 273 in '64, '65, '66 and '67. Didn't check later years 'cause we're not talking about later years.
