It is currently Wed Nov 25, 2026 1:31 pm
PostPosted: Sat Jul 07, 2007 9:58 am
my car is all put together with no motor and the ride height seems too high,the adjusting bolts are sticking out from under the control arms by an inch so its only going to get worse.
is it possible i installed the lower control arms withe the socket that retains the torsion bar in the wrong place,or will the weight of my engine make that much of a difference.i had about 320 lbs. on it and it barely moved which leads me to suspect its the lca's.how much space should be between the frame and the rubber bumper on the lca?
thanks
PostPosted: Sat Jul 07, 2007 10:40 am
It sounds like you may have the hexes one notch off if it's sitting that high.
"Mad Scientist" Matt Cramer
'66 Dart - turbocharged 225
PostPosted: Sat Jul 07, 2007 12:49 pm
i was told it was'nt possible to put them in wrong,so i guess that is what my question is.thanks
anyone else got there 2 cents?
