It is currently Sat Nov 21, 2026 6:09 pm
PostPosted: Mon Jul 09, 2007 12:51 am
THe offenhauser Home Page says a 5041 fits only Fit 1960 to 1968 Slant 6 Only. It has a setup for 2 One bbr Carbs. I found a Place which has it with 4 1 bbr Webers. Will a offy 5041 fit a 1973-74 Dart with a 225 Slant 6 in it. I don't want to waste $600.00 if it will not fit. Mine has an Auto. With the Cable Linkage. Any Problems. I Just switched from 86 to 88 fiero gt's with 280hp Motors. v-6's. Please Help a New MOPAR guy Out Please. Ron or 909-350-2827... California.
Ron E. Burger
Now trying my Hand at restoring a 73 Dart Swinger Barn Find. No Rust, Factory Paint and only 1 dent. Kool
PostPosted: Mon Jul 09, 2007 1:31 am
where did you find the four 1 bbl webber manifold and who makes it? Four upright carbs would look cool but the nightmare of linkage would be a slight deterant. if its a four side draft i would REALLY like to see it! :shock:
Even in moderation i am excessive!
PostPosted: Mon Jul 09, 2007 6:26 am
That's only because the item description was last updated...in 1968! :shock: It will fit any year slant-6. The linkage kit 5041K is designed to work with the rod-type throttle linkage used through '66; using this intake on a car with cable-operated throttle (especially with automatic transmission) will require some fabrication and adaptation.
I've seen the 5041 adapted to accept a pair (2) of 2bbl Webers, is that what you're talking about?
What is it that you are hoping to accomplish?
Users browsing this forum: Ahrefs [Bot] and 4 guests
