It is currently Mon Nov 30, 2026 4:40 am
 Post subject: Bellhousing cover plate?
PostPosted: Mon Jul 09, 2007 12:10 pm
Hello everyone,
Got my Dart in a covered garage for the summer (yay!!!!) and I just started to remove the engine. I wanted to disassemble the engine from the trans but I already found myself stuck...
There's this thin steel cover I have to remove to access the flexplate to converter bolts but I don't know which bolts hold it.
I removed the two on the bottom which seemed to be the only one but then it seems I have to remove some other bolts from the bellhousing...
Do you have a picture of the part so I can see which ones I have to unbolt?
Quite a silly problem I admit but if someone has a picture, I'll go faster tommorow...
Thanks a lot,
Marc
PostPosted: Mon Jul 09, 2007 12:36 pm
It has been a while, But i think the cover is kinda wedged in there...
Try to give it a good tug, just don´t overdo it...
PostPosted: Mon Jul 09, 2007 6:04 pm
Mine has a mounting plate just under the starter that has two 9/16 bolts that also hold the access plate to the trans. It may be differant for yous but somthing to look at.
TF
Even in moderation i am excessive!
