| Bellhousing cover plate? https://slantsix.org/forum/viewtopic.php?t=23977 |
| Author: | marc426 [ Mon Jul 09, 2007 12:10 pm ] |
| Post subject: | Bellhousing cover plate? |
Hello everyone, Got my Dart in a covered garage for the summer (yay!!!!) and I just started to remove the engine. I wanted to disassemble the engine from the trans but I already found myself stuck... There's this thin steel cover I have to remove to access the flexplate to converter bolts but I don't know which bolts hold it. I removed the two on the bottom which seemed to be the only one but then it seems I have to remove some other bolts from the bellhousing... Do you have a picture of the part so I can see which ones I have to unbolt? Quite a silly problem I admit but if someone has a picture, I'll go faster tommorow... Thanks a lot, Marc |
| Author: | Rust collector [ Mon Jul 09, 2007 12:36 pm ] |
It has been a while, But i think the cover is kinda wedged in there... Try to give it a good tug, just don´t overdo it... |
| Author: | wicked/six [ Mon Jul 09, 2007 6:04 pm ] |
Mine has a mounting plate just under the starter that has two 9/16 bolts that also hold the access plate to the trans. It may be differant for yous but somthing to look at. TF |
