It is currently Wed Nov 25, 2026 4:45 pm
PostPosted: Mon Jul 09, 2007 2:36 pm
Hope this is the right section to post this. Not a sale advert as yet as not the section for it, but more an info gathering question.
1971 Dart Swinger. Did the swap to large bolt pattern discs. Removed the existing disc brakes which are the small bolt pattern 4 piston type. Believe they are called Kelsey Hayes type? Car ran, drove and stopped great, just wanted to go LBP to match the LBP rear end I put under the car.
What I did was to unbolt the upper control arms, lower control arms, inner tie rod end, strut rod and brake hose. Took the whole assembly off in one piece. Well, did take the strut rods out on their own as they were in the way, but they are included. That mean that you would get the upper and lower control arms, tie rods inner and outer with sleeve, spindles, calipers and mounts, strut rods, discs with bearings etc. all still assembled. Basically the whole thing.
As I said, ran and stopped fine. No grab or pull that I could feel. I would consider though that you might want to repack/check the bearings, maybe kit the calipers did see some rub holes on the dust boots, replace the pads. You know, standard stuff just to be sure. If you are like me, you would replace the upper and lower ball joints and the control arm bushings. Basic rebuild stuff as they are getting on a bit.
What would they be worth? Considering selling them to offset costs and getting to be the only way to afford trying to get the Dart completed.
Cheers
From Mopars to classic Minis and back to Mopars in 19 years flat!
Will work for roast chicken crisps!!
PostPosted: Mon Jul 09, 2007 2:50 pm
They're worth what the market'll pay! Yeah, I know, big help...I've seen these setups in that general condition go for $75, and I've seen them go for $275. How much meat have the rotors got left on them?
PostPosted: Mon Jul 09, 2007 3:05 pm
Good question. Let me go measure with the old digi calliper and see.
 Post subject: Where's the beef?
PostPosted: Mon Jul 09, 2007 3:22 pm
Sorry, could not resist the subject line on this one. Just measured and then called Checker/Shucks/Kragen to see what the specs are. Using my digi calliper in multiple spots I get roughly .815 on both rotors. Pads actually look pretty thick and new also.
The info I got from the auto store was as follows:
Discard at .780, Minimum turn down size is .790, New is listed at .810
I do have a couple of pictures of them sitting on the bench, but I'll need to figure out how to get them on this board.
Cheers
PostPosted: Mon Jul 09, 2007 3:44 pm
Dimensions you got are right, but then how are we getting 0.815" on used rotors that were 0.810" new? :twisted: Possibly a ridge of rust or crud at the outer edge...?
Photos would be great. These KH brakes are (obviously) rebuildable, but some of them are more rebuildable than others...
